Lone Star Mopars • View topic - charlie's 68 charger project
New Topic Post Reply  [ 17 posts ]  Go to page
PostPosted: Sun Mar 11, 2012 6:23 pm
workin on heads & intake
PostPosted: Mon Mar 12, 2012 12:58 am
What do you have them flowing?
Pretty sweet you've got a flow bench!
PostPosted: Mon Mar 12, 2012 12:17 pm
with clay around port @ .500 267 & then backwards out of the box super stealth heads ,been workin on one intake port using my flow bench,so far 320 cfm @.550 with 4.375 bore,im running 4.310 bore & it drops flow to308cfm,but im just starting,we will see when it goes to the track, my smaller bore is an issue ,was wanting to use my orig 383 & stroke it 496 ,but i think i might get a 400 block & go that route.also my tunnel ram kills the flow down to 270,did a little work on intake & got 284 but im gonna have to weld up intake in some places to get the correct port taper its smaller at the plenum opening than at the head i will keep ya'll up to date on my progress,but it will take awhile to get some more data,i want 340 cfm @.650 through the intake sooooo i need to find a 71-72 400 block
PostPosted: Tue Mar 13, 2012 6:08 pm
1st pics are the day it came home
PostPosted: Tue Mar 13, 2012 6:10 pm
more
PostPosted: Tue Mar 13, 2012 6:52 pm
more
PostPosted: Tue Mar 13, 2012 8:11 pm
Pretty good start, can't wait to see more
PostPosted: Tue Mar 13, 2012 10:25 pm
PostPosted: Wed Mar 14, 2012 12:41 pm
w
PostPosted: Wed Mar 14, 2012 5:46 pm
removed factory under coating & epoxied
