 Post subject: got a tune done
PostPosted: Mon Feb 04, 2013 10:34 am
Some of you know that I was going to keep my charger stock, but I had a tune put on my car and it shifts great now. I did not get to be there when they did it so I have little info on what was done. I was told they remapped the pcm but I did not get a tuner for the car he used his lap top to do it. He said try it out and see how it works and not to tell anyone that he did it :?: Stock it was 304 at th RW and with the tune 344 at the RW :o I took it to the GTG and it ran good like I said it shift hard and fast but I can not tell much more HP :?: I drove it some that night and on Sunday, I was going to run it one time with a bud that has a 2007 Charger we started at 40mph and ran to 120mph at that point my car shut off :evil: It took a bought 10 times to get it to start. I took it to dodge to put on a new state inspec on it and the check eng was on so he ran a scan on it and wiped out the code for bad fuel pressure now it will not shift as hard or fast and a littel down on HP do you think that it removed the tune from the car :?:
 Post subject: Re: got a tune done
PostPosted: Mon Feb 04, 2013 5:30 pm
Yep, tune is gone...
Anytime the dealer connects it pretty much flashes what it wants. The guy that tuned it should have told you to pull the tune, or come back to him, before going to a dealer.
If his price originally plus whatever this might be is close to $250 total, I would just spring for a hand held. You can install canned tunes, return to stock, and custom tune with either the inTune or Trinity from DiabloSport. Another perk is you can actually read and clear DTCs with either.
It could have been crap gas or an issue with the tune that caused the trouble. Did he spec out a fuel to run? Gaining 40+ on the EVIC (guessing that is where you ran it) I would think it was a 91 tune...
Hopefully the guy will reflash for free or get you a good deal on a handheld etc. If it was a custom tune for a similar car it might not quite be tailored to your setup...
Keep us posted.
